Author Topic: Exhaust manifold for a 1.8 K-Jet  (Read 1827 times)
Offline bmouthboyo
« on: 13 May 2009, 21:03 »
Hi Guys,
I have just bought a T25 camper with a 1.8 K-Jet engine (i think), and have found a crack in the exhaust manifold.
Basically this will fail the MOT wont it?
If so whats my best option? reweld or replace?
If replace anyone know where i can get one?
Thanks
« Last Edit: 13 May 2009, 22:12 by bmouthboyo »
Offline danny_p
Re: Exhaust manifold for a 1.8 K-Jet
« Reply #1 on: 13 May 2009, 23:46 »
yup thats a crack,   problem is been a conversion you'v bought off someone you can never be 100% sure what bits were used.
you chould weld it  but cast dosent weld very well stick welder and high nicel rods is best bet but its a pita and will probaly crack again.  i bet is a 1.6 NA diesel exhaust manifold
unless it's blowing lots it'll probaly pass the mot
« Last Edit: 13 May 2009, 23:48 by danny_p »
all the VW's have gone bar 1.
« Reply #2 on: 14 May 2009, 00:06 »
I welded one up once, could be worth a try 1st.
Offline bmouthboyo
« Reply #3 on: 14 May 2009, 00:07 »
damn nightmare, its all pretty tight down there so could do with identical part. would there be an part code on it?
Would taping it help? it does blow enough that if i put hand near it i can feel it.MOT fail?
if it passed mot, what would worst case scenario be just leaving it as is?
thanks
« Reply #4 on: 14 May 2009, 00:09 »
thanks
Taping won't work very well due to the heat, leaving it as is could cause issues with how it runs.
Offline danny_p
« Reply #5 on: 14 May 2009, 01:05 »
stitching ( drill tap bolt drill tap bolt ) don't work on manifolds
welding them is a pig,   on tractors when ther;s room i clean the manilfold off in situe and fire the bugger up and give it some load ont he pto so the manifold gets HOT stop the motor  then welde lots of current with a high nickel rod then start it back up again to stop things cooling to quickly.
to try and weld that you'll have to find a scap head or somethign to hold the manifild true while you weld it and heat it up with gas first
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 14 May 2009, 11:28 »
That looks to be a 1.6D NA manifold on there.
You need to lose that, as it will be stranglifying the engine.
Get a Golf GTI manifold and fabricate a pair of downpipes, into one, into a single box.  When I did one i just put the pipe into a GTI backbox - worked well and sounded fine.
Offline Steve_B
« Reply #7 on: 14 May 2009, 12:17 »
I have the manifold from a 8v engine going spare if you want it. Does have a hacked off downpipe attached to it that'll be a pig to get off though.
Offline bmouthboyo
« Reply #8 on: 14 May 2009, 18:22 »
problem is i guess the converter put that smaller manifold in there for a reason as he seemed to know his stuff with a full engine replacement. I am guessing the normal gti manifold wont fit as its tight in the camper engine bay.
If i take this cracked one out will there be a part number on it? That might help.
Otherwise does anyone know if a gti manifold is much bigger?
Thanks a lot guys couldn't do this without all ur help.
Offline danny_p
« Reply #9 on: 14 May 2009, 19:08 »
gti manifold will fit in the hole. need to custmise the exhaust tho not exactly complicated.
made a pattern for a 4-1 when i was getting into idea of camper engine conversions then i came to my senses
