Author Topic: door hinge pins?  (Read 1489 times)
Offline skem55
door hinge pins?
« on: 13 May 2009, 20:33 »
ne one have an approach to changing these? f**kin little kunts wont come out of the hinge! lol
stuart
Offline 16vLeroy
  • Grr bloody car, if everything was as reliable as a
Re: door hinge pins?
« Reply #1 on: 13 May 2009, 22:10 »
You mean the little suckers with the 10mm nut underneath?
Close the door half way, then knock 'em out with a hammer.  :wink:
Offline skem55
« Reply #2 on: 13 May 2009, 22:12 »
no 10mm nuts just the pin, ill not get the beating stick in there with the door half shut lol
Offline 16vLeroy
« Reply #3 on: 13 May 2009, 22:17 »
I find that closing the door 'slightly', makes it 'slightly' easier.
Hammer - it's the tool of a pikey, but it gets the job done!
Offline skem55
« Reply #4 on: 14 May 2009, 00:22 »
guessin in the up direction?
stuart
Offline antogoof
  • bbm mk2 g60
« Reply #5 on: 14 May 2009, 00:39 »
yeah and they are a nightmare to get out, watch out though i changed 2 on my old 3 door and its the hinge that was worn and needed replacing :smiley:
mk2 bright blue met bits wanted in north west.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #6 on: 14 May 2009, 01:02 »
Your old pins are worn! and are hung up on the hinges..
Unbolt and remove the door, pins should now come out relatively easy, as they are no longer under tension, knock the top pin upwards, and the bottom pin, downwards, use, plenty of WD40 to help, lubricate new pins with copperslip...
Tom
« Last Edit: 14 May 2009, 01:14 by thom89 »
