Author Topic: Mystery amp drain on new battery  (Read 1195 times)
Offline bigtitt
« on: 13 May 2009, 12:19 »
Ok you brainyaks work this out:
Brand new battery, all the fuses pulled, amp meter shows >250 Ma drain with the multi meter between wiring loom and battery.
Where can I look next for the drain? There was an old clifford alarm which was removed, I cant find any box for it but would that bypass the fuse box?
Offline jezza16v
Re: Mystery amp drain on new battery
« Reply #1 on: 13 May 2009, 12:55 »
OK, if your 'amp' measurement is correct you have something around 3W drawing the current. Check the glovebox light isn't on, that's 3W. Check boot light as well, but that's 5w I think.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #2 on: 13 May 2009, 12:55 »
Radio memory perhaps?
Offline bigtitt
« Reply #3 on: 13 May 2009, 13:45 »
None of these as the all the fuses are pulled out and radio disconnected!
Offline danny_p
« Reply #4 on: 13 May 2009, 20:10 »
alarms and immob  if has aftermarket crap fitted
all the VW's have gone bar 1.
Offline l333
  • mk2 8v....mk3 8v....mk3 16v.... who says im greedy
« Reply #5 on: 13 May 2009, 22:17 »
hi have had alternator diode packs gone tits up before and draw current try disconnecting main feed terminal and rechecking
