Author Topic: bolt stuck bloody tight  (Read 3205 times)
Offline monzablue16v
Re: bolt stuck bloody tight
« Reply #10 on: 12 May 2009, 20:05 »
Vice grips will just mash the head then you will have a problem, plusgas is useful stuff or a proper penetrating oil. Big bar over the end of the socket/spanner or a nice big breaker bar :)
Offline xxstaggyxx
« Reply #11 on: 12 May 2009, 20:22 »
well if vive grips might mash the head up looks like ill just use the bar over the spanner or soect what would you say is the best penatrating oil to use
Offline james_16v
  • 1986 Golf GTI 16v
« Reply #12 on: 12 May 2009, 20:46 »
Plusgas is meant to be one of the best but ive never found it for sale anywhere when I needed some in a rush.
Ive always had good results with the 3 in 1 brand penetrating spray, you can pick that up in Halfords etc
Offline wil0
« Reply #13 on: 12 May 2009, 20:50 »
keep applying penetrating oil, apply it half a dozen times over a couple of days let it really soak in, use a breaker bar or a socket with a big bit of scaffolding/tube on the end. If that doesent work, heat it up!
3Door Oak Green 91 MK2 16v GTi
Offline xxstaggyxx
« Reply #14 on: 12 May 2009, 21:01 »
cheers for all the advice guys ill get some good penatrating oil and let it soak in for a few days then get the big bar out and a nice strong socket
Offline Ben Lessani
« Reply #15 on: 12 May 2009, 21:21 »
I hate to be the one that doesn't follow the trend - but there is absolutely no point in putting pentrating oil on a bolt head - it goes on threads, like studs.
On a calliper bolt, there is no access to the threads, so putting oil on won't help one iota.
http://www.golfgtiforum.co.uk/index.php?topic=49436.msg871824#msg871824
The best method has already been mentioned, get good vice grips and clamp down TIGHT, then undo it. If its the allen head bolts (as above), then you can get it off by whacking it a few times with a hammer and loosening it off with vice grips. When its off the car, grind flats onto it to bring it to 11mm and refit (or buy a new one).
If you are refering to the 13mm hex bolts - then a good quality 6 sided spanner/socket with an 18" breaker bar should make light work of it.
Offline danny_p
« Reply #16 on: 13 May 2009, 00:33 »
best way to get those off is with a hex bit set.   when the head rounds out get out a torx bit thats just a bit to big and batter it in by the time you put the ratchet in the beating has helped free the threads anyway
all the VW's have gone bar 1.
VeeDubGTI16v
« Reply #17 on: 13 May 2009, 12:58 »
noticed in the 1st post you used a torque wrench to try and undo it - bad idea. its probably inaccurate now!
Offline xxstaggyxx
« Reply #18 on: 13 May 2009, 15:51 »
well i got the bolts out i used a spanner and a nice big breaker bar iv also got some new bolts to reaplace the ones i took out cheers guys for all the advice and information im glad i joined up
Offline luellin
« Reply #19 on: 30 May 2009, 21:04 »
if you have a welder or jnow someone that dose weld a nut onto the tip and use a spanner
