Author Topic: can any of you mk3 guys help???  (Read 1031 times)
Offline juleshs
« on: 11 May 2009, 21:07 »
Oreet
i have a 1994 mk3 1.9td in my mk2. The problem is the glow plugs do not warm up when i turn the key, i am havig to warm them up with a manual switch direct to the battery i have tried a new relay still wont work
Also i have a lot of air bubbles in my fuel lines, not effecting performance but is this normal
Re: can any of you mk3 guys help???
« Reply #1 on: 11 May 2009, 23:57 »
Not 100% sure but most glow plug set ups have a timer / control unit as well as a relay, if so that might be the problem.
Offline juleshs
« Reply #2 on: 12 May 2009, 12:06 »
any idea where i would find this
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 12 May 2009, 21:17 »
the relays have a relay in the fusebox (have a look in the maintnence section as theres some diagrams in there) but seriously you shouldnt have any air in a diesel  :shocked: check all the pipes to the injectors as these fail with age/diesel contanimation!
