Author Topic: I can smell petrol fumes :(  (Read 2280 times)
Offline Burnsy
« on: 07 August 2004, 08:40 »
I can smell petrol fumes coming from around the rear of the engine near the bulkhead on the drivers side.
Is there a filter around there or petrol pipes as i cant see any leaks or drips anywhere just a smell of petrol.
TiA :)
Its on a VR6 by the way
Im thinking this my only appear when first starting the car but need to check after a run as ive only noticed it this morning (wife brought it back panickng)
"OMG the cars about to blow up"
« Last Edit: 07 August 2004, 09:46 by Burnsy »
golfvr6
Re:I can smell petrol fumes :(
« Reply #1 on: 07 August 2004, 13:43 »
The rubber fuel lines run from the rail to by the brake master cylinder. Probably need replacing, only cost about 10 quid.
golfvr6
« Reply #2 on: 07 August 2004, 14:38 »
 :D
« Last Edit: 18 August 2004, 22:39 by golfvr6 »
golfvr6
« Reply #3 on: 07 August 2004, 14:39 »
 :D
« Last Edit: 18 August 2004, 22:40 by golfvr6 »
golfvr6
« Reply #4 on: 07 August 2004, 14:40 »
 :D
Offline Burnsy
« Reply #5 on: 07 August 2004, 20:54 »
Thnxs yet again m8 for your detailed reply :)
All seems ok but will keep my eye on it
golfvr6
« Reply #6 on: 08 August 2004, 00:05 »
Check the rubber fuel hoses that go into the rail very carefully, they are known to split/wear over time.
Problem is, they may only leak when the engine is cold, then seal when engine has warmed. Still potentially dangerous.
