Golf mk2
Is my alternator knackered
Topic: Is my alternator knackered (Read 1653 times)
r7quad
Just got here
07 August 2004, 02:24 »
Hi
When my lights are on, on my 1990 8 valve you can notice that the lights get brighter and then duller. Does this meen that the alternator is knackered or it could it be something as simple as needing a new belt, cause it does sqeak a bit in the wet !
Ben
Blue MK2
Guest
Re:Is my alternator knackered
07 August 2004, 12:05 »
seems to me like its doing its job. If it squeeks then give it a little WD40 to shut it up or change it.
golfvr6
Guest
07 August 2004, 13:56 »
The lights is probably down to a poor earth connection.
DO NOT spray WD40 on a v-belt, if it squeals then check the tension, or if it still squeals when the tension is correct, replace it.
Dizzie
Forum addict
Make friends with your fast
07 August 2004, 15:45 »
change the earth lead. ?2.
Mk4 Golf 150PD
Golf mk2
