Author Topic: Horney's 'James Shead' 1988 BTCC Golf GTI replica build.  (Read 360408 times)
Offline Horney
Re: Horney's trackday MKII 8v - Project late 80's BTCC replica.
« Reply #870 on: 09 September 2010, 10:31 »
Well after last nights rather eventful No_rice it appears my oil pressure problem isn't fully solved. It's not bad at high rrevs but at idel it's pretty shocking. I suspect that ther eis still some plastic swarf from the old plastic baffle that was floating around in the engine that's started to block the pick up pipe again.
Looks like Saturday will spent pulling the sump off for the this time this year and having a look/clean out before putting it back together for the Autosolo on Sunday. Really starting to think standard ABF may well be on it's way as this engine is starting to do my head in!
Nick
Offline JonLeeper
« Reply #871 on: 09 September 2010, 16:10 »
If oyu don't want your engine, I'll take it off your hands.  you wont even have to pay me much!!!!!!!  :evil:
Offline archie837
« Reply #872 on: 09 September 2010, 17:11 »
Eventful no rice. Lairy fleet services hoebag. Did she not realise there was an extra hundred odd people buying dinner there. Or maybe she did and that's why it took her so long to come out.
What's gonna happen next month?
Also VR the track sl@g
Project longterm Airbanger.
PD150 Anni daily
Offline Horney
« Reply #873 on: 09 September 2010, 18:13 »
Dunno about next month, have to wait and see I guess.
VR? I have enough understeer already thanks! :grin:
Offline archie837
« Reply #874 on: 09 September 2010, 18:55 »
Just put another one in the boot to drive the rear wheels
PD150 Anni daily
VeeDubGTI16v
« Reply #875 on: 10 September 2010, 08:03 »
put some oil pressure numbers up nick. Should be roughly half the pressure at idle of what it is under load.
doesn't sound like the plastic is back though, i would have thought that would show up at high revs when the pump is sucking its hardest   :undecided:
« Last Edit: 10 September 2010, 08:07 by veedubgti16v »
Offline Horney
« Reply #876 on: 10 September 2010, 09:07 »
15 psi at idle and about 65 psi at 4K
Nick
VeeDubGTI16v
« Reply #877 on: 10 September 2010, 19:21 »
Under load is ok, so i wouldnt worry too much
Offline Horney
« Reply #878 on: 10 September 2010, 19:52 »
My worry is that it gets worse during the day on sunday. Gonna pull the sump and have a look, will only take a couple of hours all in including running the oid through some gauze. .
Nick
Offline SoundillusioN
« Reply #879 on: 10 September 2010, 20:05 »
just caught up.... i hope you find a little problem for your sake, then you can sort it and put your mind at rest.. its annoying when youre not happy about something but dont know whats up... had any performance issues?
