Author Topic: Horney's 'James Shead' 1988 BTCC Golf GTI replica build.  (Read 358666 times)
Offline Horney
Re: Horney's trackday MKII 8v - Project late 80's BTCC replica.
« Reply #660 on: 12 April 2010, 12:19 »
Standard 16v's seemed to be pulling low 16's yesterday so yeah I'm chuffed. Lack of grip was a real issue, with all the neg camber up front it was just ligting the wheels up on launch and the change to 2nd. I always thought pod would be grippier but I got better traction off the traffic lights on the way home.
Nick
VeeDubGTI16v
« Reply #661 on: 12 April 2010, 12:37 »
lol just seen your sig  :grin:
you forgot the rust pack
Offline Horney
« Reply #662 on: 13 April 2010, 09:17 »
Some pics from zee pod
Nick
Offline Horney
« Reply #663 on: 15 April 2010, 10:46 »
New radiator fitted and no more water leaking out = Good
Still getting Oil temps of 110 on the motorway and 96-98 tooling about on A and B roads = Bad
nick
Offline Diamond Hell
  • Opinions я Us
« Reply #664 on: 15 April 2010, 11:50 »
And HDN haven't collected the box sitting in my hall = bad.
Cage rattling forthcoming.
Where are you on Sat AM?
It's very likely we'll be hauling up the M3
Offline Horney
« Reply #665 on: 15 April 2010, 11:53 »
I should be at home mate, depends if Jord has work for me. Mrs Horney will be in though.
If I'm in I can meet you somewhere easy enough.
Nick
Offline Horney
« Reply #666 on: 18 April 2010, 14:24 »
Oil cooler collected from Mr Hell at the side of the M3. It's the MKI GTI style which has a different filter housing with an inbuilt thermostat and two take offs for the air/oil cooler. Spent yesterday afternoon doing some research on whether to run with or without the stat and figuring out how to get it all to fit. Today I've cracked on and so far got the oil cooler itself physically mounted in the car by fabricating a bracket for the slam panel and hacking out the lower part of the slam panel.
2 problems/issues that have arisen are that 1) the new filter flange is a bit thicker that the old on so not sure the bolts will be long enough and 2) I've not been able to get a filter housing gasket so I'm going to make one out of weetabix packet, gulp.
nick
Offline T_J_G
« Reply #667 on: 18 April 2010, 16:56 »
Pop down GSF :lipsrsealed:
Offline JC
  • Back in the North.
« Reply #668 on: 18 April 2010, 17:05 »
 :grin: :grin: :grin: :grin: :grin:
Offline Horney
« Reply #669 on: 18 April 2010, 17:59 »
Result. Old gasket came off in one piece and in good condition and was re-used. Been out for a run and the temp never got above 92 despite it being a warmer day and I gace it some proper welly.
Down side is Oil Pressure concerns. The gauge used to be hooked up to the filter housing but due to the new housing there was no space so switched it to the head instead. Once warmed up I was getting only 25psi at full chat and 0 (yes 0!!!!) at idle. I;ve only ever had the buzzer go off on a trackday and that was once so I'm a bit confuzzled. New oil pump next weekend me thinks and if that doesn't sure it then time to get it booked in at a garage for proper diagnosis. Not going to track it till I'm sure I know what's going on.
nick
