Author Topic: Horney's 'James Shead' 1988 BTCC Golf GTI replica build.  (Read 360084 times)
Offline Horney
Re: Horney's MKII 8v - Rolling on 17's pg 42!
« Reply #420 on: 18 November 2009, 13:46 »
T1-R road-based all-weather goodness FTW.
That's the plan for the spring. At the moment it's goignt o be getting a mixed bag of branded part worns to see it through the winter. As it'll only be doing the odd meet and sunny blast that works out nicely while I use my spare money each month to get my finances in better order in advance of my impending redundancy.
Although I have put 4 x T1R's or Uniroyal Rainsport 2's on my crimbo list!
nick
Offline Horney
« Reply #421 on: 21 November 2009, 15:08 »
17's now gone so it's back on the 15's and looking better. Should be ordering 4 x Toyo T1R's in the next couple of days (Camskill have 195 50's on special offer for £28!) and then I need to get them fitted and I can start taking it to meets and to work on sunny days again.
Stuff that needs sorting before the next track day is growing as I find stuff that needs replacing. So far it deffo needs:
* Pair of front discs (Grooves have almost completely worn away)
* 2 x Outer CV joints
* Seems to have developed another oil leak despite not being used so I need to investigate where that's coming from.
* Oil pressure gauge (Cause I hate not having one in a car that gets pushed this hard)
* 2 x Toyo R888's in GG compound for the front.
* Welded in brace/harness bar.
I'd also like to get some buckets and harnesses in there but funds are going to be very tight over the winter so it's unlikely. I will soon be getting the grinder out though and get cracking on more lightening!
Nick
Offline Horney
« Reply #422 on: 01 December 2009, 21:44 »
While window internet shopiing found the bucket seat I really want.
http://www.ybracing.co.uk/page1.php?sitepage=4&part=615
Nick
Offline Diamond Hell
  • Opinions я Us
« Reply #423 on: 01 December 2009, 23:31 »
Only designed for a 4-point harness.
Ewww.
Offline Horney
« Reply #424 on: 02 December 2009, 09:32 »
Ewww.
True dat but seeing as I can't afford it it's not really even an issue, ha ha.
Nick
VeeDubGTI16v
« Reply #425 on: 02 December 2009, 09:58 »
its ok for you to say get 6 point harnesses dh, you have had kids already!
personally i like my balls being operative, hence 4 points in mine  :grin:
Offline JonLeeper
« Reply #426 on: 02 December 2009, 10:29 »
Fitted 6 points in mine, as they were free, and didn't find that I was contricted.  The crutch straps come up and then split either side with plenty of room between.  The straps have to pass through rings mounted quite a long way back from the buckle on the lap belt and are not really near the "wedding tackle" at all.  I can see that a 5 point might get a little uncomfortable but the 6 was just snug.  Having seen the mess that can arrise from "submarining" under a, admitidly poorly fitted, 4 point it is not worth the risk.
Very happy with mine and the seat was a Corbeau Pro Sprint XL £180 delivered so didn't break the bank either.
  • Opinions я Us
« Reply #427 on: 02 December 2009, 12:04 »
You shouldn't believe everything you read on the interwebs.
Do the straps up tight and it's not an issue.
VeeDubGTI16v
« Reply #428 on: 02 December 2009, 12:07 »
its the picture that freaked me out, ill have to find it for you  :sick:
Offline Horney
« Reply #429 on: 02 December 2009, 12:11 »
Please don't make my thread NSFW, ha ha.
Nick
