Author Topic: Horney's 'James Shead' 1988 BTCC Golf GTI replica build.  (Read 358901 times)
Offline Thom89
  • Looking for an "Icebreaker"
Re: Horney's 'James Shead' 1988 BTCC Golf GTI replica build.
« Reply #1290 on: 09 January 2013, 00:09 »
Welding and bracing will not be a problem with the scrutieers
Blue Book 2013 says:
Quote
Any modification to a homologated ROPS (other than fitment of doorbars) is prohibited.
Isn't a 6-point bolt-in cage homologated in its unaltered form, for installation without alteration?
Relevant details here:
http://www.msauk.org/uploadedfiles/msa_forms/bluebooks/13/151_189_Common_Regulations_for_Competitors_%28Safety%29_%28K%29.pdf
Dunno where it says about roof material, but I'd guess it'd be outside the GTI Championship regs (although I appreciate Nick isn't going for that).
Details in the link are to fit to a minimum specification for fitting a roll cage, and encourages welding instead, extra bracing is also mentioned, and will be encouraged by the Scrutes
We have 2 Historic racers that have bolted cages, that have since been welded upon request, both are now fully FIA papered cars
Bolting in a roll cage will never provide, or replace any torsional integrity, it will simply give the driver little more protection in the event of an accident
Cars entered into competition, are likely to be thrown out unless welded... Track days you may, and probably will be OK. less lenient
Roof panels, I'm not 100% sure about, but sunroofs should be welded up. Cars fitted with full OTT roll cages can probably flaunt the GRP roof panel thing... if spotted that is!
The "Shell" Nick, basically has nothing tying the front of the car to the rear, this will be evident when you jack the car up under the sill ("A post") and try and open the door!
Thom
Offline Horney
« Reply #1291 on: 09 January 2013, 00:15 »
I think this is where FIA and MSA get confused. MSA regs are fully happy with a bolt in cage, it's in the blue book, from memory all the GTI champ cars I've looked in have bolt in cages. FIA international stuff may well be very different.
Shall get my nose in the blue book over the GRP roof this week and report back!
Nick
Offline Thom89
« Reply #1292 on: 09 January 2013, 00:49 »
Nick
 :cool:
Thom
Offline Diamond Hell
  • Opinions я Us
« Reply #1293 on: 09 January 2013, 12:13 »
Logbooked cars are a rather different scenario than something prepared for sprinting, or something like the Golf GTI Championship, where bolt in cages are definitely part of the regulations.  Welding and extra bracing ARE mentioned, but that would depend on the overall set up of the cage IMHO.
You mean more lenient  :wink:  I think Nick's bolt-in cage would get into the GTI Championship.... provided there weren't bits welded to it, voiding the homologation of the cage..... Looking at cars in the VAG Trophy they DO have full weld-in cages, but that's a significant hop up from the GTI Championship.
The roof would be an immediate fail in the GTI championship though because:
Quote
1. Unless specifically authorised in these regulations, the lightening of components or panels in any way, whether via removal of metal or otherwise is prohibited. Specifically but not exclusively this includes removal of any unused bracketry welded to the bodyshell or other components: seat rails, seat front cross member, rear seat base frame, roof tin supports, seat belt anchor backplates, rear seat hinge and retaining brackets.
I think replacing the roof with a GRP skin othingys as 'removal of metal'.  :grin:
Offline Horney
« Reply #1294 on: 09 January 2013, 12:39 »
My shell was non complaint with the GTi champ before I even bought it as it's has the arches chopped for wheel clearance and the rear seat brackets removed to run a Corrado rear bench. :grin:
Offline Thom89
« Reply #1295 on: 09 January 2013, 13:30 »
TBH, I'm not arguing the toss in the rules and regs, my point is that with the steel roof being removed, the roll cage should now be welded to bring the strength of the shell back up to what it should be...
Just had a quick ask of the lads, none of us have ever heard about not being allowed to weld in a roll cage...
Thom
  • Opinions я Us
« Reply #1296 on: 09 January 2013, 17:52 »
Oh I agree, it's just a weld-in cage probably would have been a better starting point than a bolt-in, given the surgery that's going on now.
Offline Thom89
« Reply #1297 on: 09 January 2013, 21:33 »
Its all still doable with the existing cage, but a six pointer would be ideal
Just hope that you've not been disheartened Nick, get on with the grafting!
 :cool:
Thom
Offline Horney
« Reply #1298 on: 09 January 2013, 22:09 »
Not at all disheartened chaps, let me jsut hop of the edge of this motorway bridge and I'll be right with you. :grin:
Offline Thom89
« Reply #1299 on: 09 January 2013, 22:35 »
Thats the spirit
Thom
