Author Topic: fuel pump not priming  (Read 1012 times)
Offline lewisvr6
« on: 10 May 2009, 19:24 »
i have just done an engine conversion on my mk3 golf and now the fuel pump will not prime, i had to take the old loom out the fuse box and fit the new one in, was wondering if anyone new which plugs and relays do what in the fuse box? the loom is off a obd 1 vr6 cheers
Re: fuel pump not priming
« Reply #1 on: 11 May 2009, 08:37 »
what was the car before, did you fit the right VR ecu relay?
Offline lewisvr6
« Reply #2 on: 11 May 2009, 17:44 »
it was a 1.4 8valve, i got the fuse box with the engine, there was no extra relays both boxes had the same in each, should there be more?
« Reply #3 on: 12 May 2009, 15:32 »
early VR should have an ECU relay in slot 3, did the vr fusebox come with one there?
oh and the fuel relay is bottom right, does it click with the ignition?
« Last Edit: 12 May 2009, 15:35 by rubjonny »
