Author Topic: Front indicator project...  (Read 1797 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 09 May 2009, 08:07 »
Im not exactly sure what the project is yet, but does any one know how to remove the lense of the front indicators from a MK3?   They are clear GTI type,  i can see sealent, dispite me digging this out its not moving and i dont want to force it... any one every tried removing them before?
Cheers.  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Adam
Re: Front indicator project...
« Reply #1 on: 10 May 2009, 12:04 »
I have a f**ked set I will have a look and butcher them for you  :smiley:
Down Hill From Here.
Offline mk3 tdi
« Reply #2 on: 25 May 2009, 19:57 »
i tried the oven trick when i tinted my fogs and headlights but could not do it.
Offline avengedslayer
« Reply #3 on: 25 May 2009, 20:09 »
i tried oven trick with the headlights and was successfull!, not sure if there is sealant on the indicators not really looked  :smiley:
Offline eightyeightmph
« Reply #4 on: 25 May 2009, 23:02 »
Thought the indicators were glued rather than sealed as such?
2016 GOLF GTD
Offline rizzel
« Reply #5 on: 16 June 2009, 16:07 »
Which oven trick is this? havent heard of it!
Offline shepgti
« Reply #6 on: 16 June 2009, 17:17 »
just heating it until the sealent goes soft so they come apart, when i did mine i just left them in the sun and they came apart easy
