Author Topic: Extra pennies for oil.............  (Read 1446 times)
Offline Tramp
« on: 08 May 2009, 09:12 »
So there it is in front of you in the shop.
A well branded oil name
A less or / Don't no brand of oil
Obviously the branded is half as much again in £ than the not so.
Choices choices?...................You think........
Is the branded oil you get worth the extra pennies?
Offline Ben Lessani
Re: Extra pennies for oil.............
« Reply #1 on: 08 May 2009, 11:26 »
I bought 25 litres for £30 Renault Motrio 10w40, as far as I'm concerned my old girl burns it no matter what I put in, no point wasting money on the good stuff.
Offline danny_p
« Reply #2 on: 08 May 2009, 13:01 »
depends on what enigne you have and how you treat it.
if you have a stock 1600 and just plod around in it  any old oil will do.  if you have a tweeked up 16v or 20vt  and you rally the carp out of and do track days ect  you need a high quality oil else it will go bang
all the VW's have gone bar 1.
Offline wil0
« Reply #3 on: 10 May 2009, 04:49 »
My dad claims its all aload of rubbish everytime i mention expensive oil. he says that the planet stuff he and i use all have the same specs and codes as the expensive oils.
Is this true?
3Door Oak Green 91 MK2 16v GTi
Offline Ben Lessani
« Reply #4 on: 10 May 2009, 10:46 »
Yep, 100% true and Ecotek valves make your car faster.
That should have been posted in the Spotted DPB thread.
Offline danny_p
« Reply #5 on: 10 May 2009, 21:53 »
oils change massivly,   when you start working an engine you'll tell the diffearance
with cheep crap oil  the temps seem to run higher and when it gets hot oil pressure just disapears and it also ages a lot faster. on the other hand a top end premium oil will run cooler doing the same work,  oil pressure will stay till it's a hell of a lot hotter and it will stay in grade a lot lot longer.
the mid range random brands are the ones to watch    semi synthetic  means pritty much anything you want it to
