Golf mk3
hardmonkeys
running oil temp???
Topic: running oil temp??? (Read 1316 times)
captin manering
running oil temp???
08 May 2009, 07:22 »
Prob a stupid question but my 8v gti was running with an oil temp of 112 thismorning on the way to work is this a little high? It usualy runs around 90 to 102
Cheers Matt
gazpowells
Re: running oil temp???
08 May 2009, 07:58 »
112 is a little high mate for normal driving but if you was driving hard then it's ok
captin manering
08 May 2009, 08:08 »
yea i was just driving to work normal speed 2 mile trip might be cause my water keeps pumping out of my water bottle hence not cooling oil.
i will investigate further today
Cable
08 May 2009, 09:59 »
sounds like it could be your thermostat, does the bottom radiator hose get warm?
Wayne
Sir Postalot
08 May 2009, 10:01 »
That seems high, my 8v never went over 95 even on a motorway trip.
Guy
Forum addict
08 May 2009, 10:05 »
nor mine...
your oil and water problem definitely appear to be linked... i'd get it sorted pronto
biggest suspect sounds like the thermostat.. check your bottom rad hose once the engine is warm as cable said
** need web hosting? contact me **
captin manering
Reply #6 on:
08 May 2009, 11:32 »
well i just looked at my oil levels and its half way up the dipstick
going to drain it out and start again. going to get a new water bottle and replace the old one and try again
Len
10k hero
Reply #7 on:
08 May 2009, 13:11 »
I've had it that high many times!
But not on a short trip!
www.sas.org.uk
www.the-ace.org.uk
Golf mk3
hardmonkeys
running oil temp???
