Author Topic: mk3 vr6??  (Read 1872 times)
Offline oliver07
  • golf gti T 200BHP
Re: mk3 vr6??
« Reply #10 on: 09 May 2009, 12:01 »
the water problem may be coming thr :rolleyes:ough the cabin filter check to see if its blocked
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
Re: mk3 vr6??
« Reply #11 on: 09 May 2009, 17:00 »
i love my vr6 best car iv ever owned and would buy another one straight away 2morrow if i needed one. much better than my vauxhalls v6's  never had a problem apart from abs sensors and brakes but thats it. i get to drive around 3-4 different cars aday and love it at the weekend when i can take my vr6 out n just get to drive it.
Offline sharki786
  • GOT BOOST??
Re: mk3 vr6??
« Reply #12 on: 09 May 2009, 22:46 »
just remember to listen to the engine when its started, listen out for the timing chain as after 85k or so they need to be replaced and they cost an arm and a leg to replace. i dnt know the sound but my mate loves his vr6's, so he knows his vr stuff everytime he buys a vr he always listens for the timing chain and never has a problem with it. if it has been replace get the proof or just listen to it while its stationary dont rev it or anything. hope that helps a bit. after that stick a turbo charger on it  :wink: OOOH suite you sir! :smug:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline spunkymonkey
  • Tepidly moist! That's what that is!
Re: mk3 vr6??
« Reply #13 on: 10 May 2009, 01:33 »
I had a vr6 for 2 weeks, very poor economy to performance ratio but sound and feel mint when driven hard!
Offline AudiA8Quattro
Re: mk3 vr6??
« Reply #14 on: 10 May 2009, 10:32 »
The chains aren't always the problem.
The upper guide rail is quite weak and can break. Also lack of service means the hydraulic tensioner won't work properly.
When i had my vr6, i replaced the upper guide rail when i replaced the head gasket.
My mate has got it now, its done over 110k miles, and chain has never needed doing.
The trick is, listen on cold start for chain rattle, if there isn't any then you probably can leave it alone.
