Author Topic: Indicators stop working on braking  (Read 1495 times)
Offline mayhewa
« on: 07 May 2009, 21:13 »
I have a 1995 Golf Mk3 GTI 16v, The indicators and hazard lights work fine until the brake pedal is depressed at this stage the indicators stop working, the brake lights work fine. Am i right in thinking that this could be an earth problem ?
Re: Indicators stop working on braking
« Reply #1 on: 08 May 2009, 10:04 »
yeah I would say so, is it the same regardless of if the car is moving or not?
there are earth points in the boot behind the carpet/foam either side, so start there :)
Is it all the inicators/hazards fail, not just the rear ones?
Offline Cable
« Reply #2 on: 08 May 2009, 10:06 »
Yh either an earth problem or you have got the wrong bulb somewhere and it is bridging a gap.
Offline mayhewa
« Reply #3 on: 08 May 2009, 10:55 »
Jumped in the car this morning to go to work, checked the indicators when depressing the brake pedal, they worked !!! then several miles down the road indicated then braked they stop working again !!! then they start working again !!!
I'll check all the earths tonight.
« Reply #4 on: 08 May 2009, 11:34 »
sounds like a loose wire then, as you're movin about its loosing connection. that being said i had a similar intermittant fault with the left indicators, if i braked and turned left the relay went off like a machine gun, new indicator stalk sorted it :)
Offline shepgti
« Reply #5 on: 08 May 2009, 11:37 »
out of intrest would a bad earth cause the idicators to contstantly flash when the door is open? is very confusing
« Reply #6 on: 08 May 2009, 12:22 »
hmm, its possible but an odd one to be sure!
sounds more liek a dodgy alarm installation, as they tend to be spliced into the indicators and the door pins...
