Author Topic: ECU Question???!!!  (Read 1480 times)
Offline ineson
ECU Question???!!!
« on: 07 May 2009, 16:51 »
Had my car in the garage for a week now but still no luck on finding the fault from this thread -
http://www.golfgtiforum.co.uk/index.php?topic=115564.0
Anyway the latest thing to try is the ECU, I have been told by the garage that if they send if off they charge around £40 to check the ECU and then a couple of hundred for a new one. This just isn’t an option so my thought was to get a second hand one off ebay or off here that would suit my car and try that.
Now I have been given the number from the garage and what I need to know is does the ecu I buy have to mathc up with the serial number exactly as there are a few different numbers available and also letters after them. Also would I need a transponder key if I got one with the same serial number.
The number on mine is 037 906 025 R
Sorry if it’s a dumb question just at the end of my tether with the car now and seriously thinking of towing it home and breaking it.
Offline ineson
Re: ECU Question???!!!
« Reply #1 on: 07 May 2009, 16:58 »
Forgot to add its a 96 P reg MK3 gti 8v if that helps.
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 07 May 2009, 19:33 »
You're on the verge of when transponders were bought in.  You could have look in Passats as well, but ETKA says Golf, Vento and Golf Variant only.
« Reply #3 on: 07 May 2009, 20:26 »
The code on the end means which version it is, I believe they have to match.
Offline ineson
« Reply #4 on: 07 May 2009, 22:04 »
Yeah some I have seen have a key and some havent, need to do a bit more research.  :smiley:
Thats useful info thanks, narrows down my possibilites but now I know what to look for.  :cool:
« Reply #5 on: 08 May 2009, 00:20 »
Just for info, you can change the transponder ring and the chip in the key if needed.
