Author Topic: cat converter  (Read 1682 times)
Offline loki86
cat converter
« on: 07 May 2009, 16:15 »
like said mk3 golf 2.0
need to know if the cat can be removed or not
if this has been posted already please give me a link so i can figure it out
thanks
Offline sleeper16
Re: cat converter
« Reply #1 on: 07 May 2009, 18:41 »
i think its around 92 same year as mk3 came out that the laws on exhaust emissions got tighter.
as far as im aware no where states you need a cat though  as long as it passes the emissions tests (which it is most likely not to without a cat)
so in short by law no but to pass mot yes :D
Offline loki86
Re: cat converter
« Reply #2 on: 07 May 2009, 19:50 »
i live out in the country so no emissions  :evil: so i dont care about those. the question i have is do i have to have it for the car to run correctly
Re: cat converter
« Reply #3 on: 07 May 2009, 20:29 »
Yes you can remove the cat and as long as the lambda sensor (if fitted) is left in place it will run fine.
Offline loki86
Re: cat converter
« Reply #4 on: 07 May 2009, 20:42 »
the lamba is that the o2 sensor or something else ??
if its the o2 i can have it placed back after i decat then
Offline sleeper16
Re: cat converter
« Reply #5 on: 07 May 2009, 21:01 »
its the sensor that is stuck in the exhaust just before the cat. if your handy with a welder just get a grinder n chop the exhaust just before the cat and weld a new section of tubing in..that's what i plan to do.
like Wayne says no running issues as long as sensors remain in place.
« Last Edit: 07 May 2009, 21:02 by sleeper16 »
sharpie
Re: cat converter
« Reply #6 on: 07 May 2009, 21:06 »
cat converter:
Offline Adam
Re: cat converter
« Reply #7 on: 07 May 2009, 23:41 »
You Scottish would eat anything!
Down Hill From Here.
Re: cat converter
« Reply #8 on: 08 May 2009, 00:24 »
Yes lambda is also known as 02 sensor, as long as it is refitted it will run fine.
