Author Topic: Modified your brake bias valve?  (Read 730 times)
Offline jamie_pyrite
« on: 07 May 2009, 09:56 »
I was out with some mk2 lads the other night and they said they've both modified their brake bias valve to compensate for them lowering their cars otherwise the rears lock up first.
Has anyone else done this? I know I haven't and I'm thinking I should do something about it!
Re: Modified your brake bias valve?
« Reply #1 on: 07 May 2009, 11:01 »
depends how low you go!  my unscientific method is to set it so the slack is just taken out of the spring, and so far ive not locked up the rears. the problem comes if you proper slam thge car, then there is no more adjustment left in the spring.
in this case I have someone stretch the spring, which involved putting it on a vw widowmaker jack and slowly unwinding it, inside a bin to prevent carnage should the spring ping off!
Offline Owen
« Reply #2 on: 07 May 2009, 11:54 »
This is something I would advise doing. Its not a good feeling when you have the back end go twitchy under heavy braking.
« Reply #3 on: 07 May 2009, 12:59 »
Thanks guys, I'll look into it then :) I'm ordering coilovers tonight to go lower!
Offline Steve_B
« Reply #4 on: 07 May 2009, 13:28 »
There's a how-to in the maintenance section  :smiley:
