Author Topic: !PLEH  (Read 5081 times)
Offline paulydixon
!PLEH
« on: 06 May 2009, 20:59 »
I'm in the process of getting these put on my mk3 anf i'm at the stage where i need to order the adapters.
Now i know i need the 4x100 to 5x130 but what sort of width should i be going for, 30mm? 40mm?
Two of them are 7x16 with an offset of 65
Two are 8x16 with an offset of 52,3
I think i'd like the fronts to maybe just sit flush with the arch, or ever so slightly protrusive. The rears i'd just like to be blatant and stick right out of the car! Any images etc i'd be gratefull too
x
Re: !PLEH
« Reply #1 on: 06 May 2009, 21:04 »
I would run 30mm to be honest.
Offline spunkymonkey
  • Tepidly moist! That's what that is!
Re: !PLEH
« Reply #2 on: 06 May 2009, 21:57 »
If its got arch trims id go for 35mm front, 30mm rear to give the desired effect your looking for.
My 25mm front with 8j wheels have a bit of tuck. id like 30mm on the front now.
Offline paulydixon
Re: !PLEH
« Reply #3 on: 07 May 2009, 22:03 »
I sort of trial fit them this evening and i've got to sday, i'm so tempted by 35 fronts and 40 rears!!!
Re: !PLEH
« Reply #4 on: 08 May 2009, 00:17 »
The only trouble is that would leave your rear offset at around 12.5 which is going to need arch work.
Offline shepgti
Re: !PLEH
« Reply #5 on: 08 May 2009, 11:31 »
have the arches flared and rolled, doesnt cost too much...
Offline daimo
  • looking for a MINT 3 door 1.8T
Re: !PLEH
« Reply #6 on: 08 May 2009, 16:36 »
which porsche wheels are these,cos i like the look of these a lot if you dont want em i bloody will lol  :wink:
Re: !PLEH
« Reply #7 on: 08 May 2009, 16:38 »
They are from a Porsche 928.
Offline daimo
Re: !PLEH
« Reply #8 on: 08 May 2009, 16:41 »
thank you very much
Re: !PLEH
« Reply #9 on: 08 May 2009, 17:03 »
thank you very much
No worries, they also made 9x16's as well.
