Author Topic: What to look for if burning oil?  (Read 2862 times)
Offline Shady Pioneer
  • graphic designer.
« on: 06 May 2009, 00:11 »
I think my car might be burning oil, no apparent leaks and there seems to be a decrease in oil level over time, could be why my cat is fudged? What should I be looking for?
Re: What to look for if burning oil?
« Reply #1 on: 06 May 2009, 00:12 »
It is harder to tell with a cat, however you should still be able to smell oil if it is being burnt, if it is I would think your valve stem seals are knackered.
  • graphic designer.
« Reply #2 on: 06 May 2009, 00:29 »
Ok so where would I be looking to smell for oil? And if it is the stem seals, and easy fix?
Offline shepgti
« Reply #3 on: 06 May 2009, 09:51 »
am i right in thinking blue smoke from exhaust suggests it burning oil.. :undecided:
« Reply #4 on: 06 May 2009, 09:56 »
Yes also you can tend to find you get puffs when changing gear.
  • graphic designer.
« Reply #5 on: 06 May 2009, 10:03 »
There's defo no blue smoke coming from the rear, any other causes at all?
« Reply #6 on: 06 May 2009, 10:21 »
Only other thing to suggest is do you have a leak somewhere.
  • graphic designer.
« Reply #7 on: 06 May 2009, 10:25 »
There's nowhere apparent, there's no wet areas or anything  :huh: I'll have to see if I can get under the car and check, that would seem more logical but it's defo not apparent where a leak would be coming from (no oil patches when car left still either).
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #8 on: 06 May 2009, 10:41 »
Leaks
Valve stem seals
Piston Rings
Head gasket
Work your way through them.  Head gaskets do tend to go on the golfs, 100,000 miles upawards and they are at risk, although they usualy hold up well if its well looked after and not overheated etc..   Valve stem seals go, A common one on valvers, again, a high milage thing...  I doubt the piston rings would have gone ... but who knows,  How fast are you loosing oil?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Guy
« Reply #9 on: 06 May 2009, 10:53 »
Leaks
Valve stem seals
Piston Rings
Head gasket
oil temperature sender? squeeze the little rubber switch cover on top of the oil cooler, if there is any oil in that then that is leaking
