Was driving earlier, parked up for 5 minutes, went into a shop and by the time i came out about half a litre of water had pissed all over the road. Filled the tank back up, got it home and no leak. had a little look around this evening letting the engine tick over for about 20 minutes, switched off and waited, no leak. Apart from loss of water i'm having no other problems, oil temp is fine, coolant temp is fine and all my sensors seem to be working as they should be. Checked my oil again, and that is fine, no watery deposits in there.
I have noticed one thing though. The expansion tank cap is usually tight on, as you'd expect. however the two times i have lost water big time and had to fill up, its been really easy to unscrew. could it simply be that the cap is in need of replacing and that water is just over flowing from this?
getting it up on a ramp tommorow morning at a garage where our work vans get done, one of the guys there is into his VeeDubs so hopefully he can lend his view on it.
