Golf mk3
hardmonkeys
What temperature should my 8v GTI be running at?
Topic: What temperature should my 8v GTI be running at? (Read 1891 times)
6sr
GTI forum regular
05 May 2009, 21:17 »
I've noticed that my car seems to be running at about 70 - 80 degrees when I'm driving. When in traffic it goes to about 90 degrees.
Does this sound right? I was thinking that perhaps a temperature sensor was playing up.
Any thoughts?
Christo77
Guest
Re: What temperature should my 8v GTI be running at?
05 May 2009, 22:13 »
That's exactly how mine behaves anyway, although i think it takes too long to warm up from a cold start.. so i'm replacing the thermostat when i can get round to it, see if it makes any difference..
6sr
GTI forum regular
05 May 2009, 22:40 »
Yeah, mine takes a while to warm up.
My last mk3 didn't do it, thats why i thought there was perhaps something up.
Khare
Serious forum addict
The bear that khares
05 May 2009, 23:02 »
water or oil temperature?
My water stays at 90 all the time, and my oil varied, normal driving about 88-90, traffic 90-94 and motorway 94-100
6sr
GTI forum regular
06 May 2009, 08:03 »
This is the water temperature, I'm getting pretty poor fuel consumption - driving sensibly around town and I'm getting 25mpg
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
06 May 2009, 08:45 »
seems a bit cold, but it could be under-reading. has the ecu temp sensor been replaced since you bought it? this also does the dash gauge.
run the car from cold and feel the bottom hose to the rad, it should stay stone cold till the temp gets to about 87 degrees, then get warm
6sr
GTI forum regular
Reply #6 on:
08 May 2009, 11:49 »
I've not changed it, but will check this out - thanks!
G60GTI16V
GTI Mk1, 2, 3, 4 now VRS Hell Yea!
Reply #7 on:
08 May 2009, 14:38 »
theres no problems there, mine runs the same
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Reply #8 on:
08 May 2009, 14:59 »
My 1.8 warms up in about 30 secconds, my diesel takes a a good 15 mins, my 1.4 took somewhere in between and all my GTIs have been about 10 mins ... never understood why it varies so much
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Cable
Reply #9 on:
08 May 2009, 15:01 »
Sounds like the thermostat is stuck open.
Golf mk3
hardmonkeys
