Author Topic: fuse problem  (Read 2801 times)
Offline 4ok
fuse problem
« on: 07 July 2003, 20:55 »
 ???  i have mk2 golf 8v 91 and some reason my windscreen wiper fuse keeps getting blown. can any1 help me
Offline modulater
Re:fuse problem
« Reply #1 on: 09 July 2003, 23:08 »
I would unplug the connector to the wiper motor and replace the fuse, if its the motor causing overload then the fuse should be ok without the motor on the circuit, If it doesn't blow connect up either a test light or volt meter and turn the wipers on, this in theory shouldn't blow as the motor isnt connected, If it does then it means that even with a low current draw the wires cant handle the load which would indicate a short circuit in the loom.
Offline 4ok
Re:fuse problem
« Reply #2 on: 11 July 2003, 00:39 »
cheers for that!! ;) it working now!!
