Author Topic: MFA & Acuracy?  (Read 1626 times)
Offline Chris36
MFA & Acuracy?
« on: 04 May 2009, 19:04 »
Hi guys just wonderig - how accurate are these??
Been running around in my Mk2 a lot more recently - seeing 38 MPG on the MFA
Is that realistic?? Not really paid any attention to the actual miles ive covered!!
Standard 8V BTW
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
Re: MFA & Acuracy?
« Reply #1 on: 04 May 2009, 19:14 »
thats good  :smiley: i use mine daily and showing 33, i do 15 miles each way from home to work, i do normally get stuck in traffic so i think that helps but do like to push the old girl when i can  :grin:
Offline Chris36
Re: MFA & Acuracy?
« Reply #2 on: 04 May 2009, 20:04 »
Do you think its actually pretty accurate then??
Offline JC
  • Back in the North.
Re: MFA & Acuracy?
« Reply #3 on: 04 May 2009, 20:08 »
mine tells me 33 mpg normally and its bollox
. even going by the fill up, record ya mileage, fill up again way is hit and miss cos your speedo thus mileometer can be way out too  :laugh:
I am long past caring,
Fill up  Drive and enjoy  :cool:
Offline hobbes
Re: MFA & Acuracy?
« Reply #4 on: 04 May 2009, 20:40 »
Talking of MFA's, can you still get the outside temp sensor?  Mine was reading 6 C today ???
Mk2 Golf GTI 16v
Mk4 Golf GT TDI
VeeDubGTI16v
Re: MFA & Acuracy?
« Reply #5 on: 04 May 2009, 20:48 »
thinking about it, if a speedo can be 10% out, then the mileage on our cars is 10% too high  :shocked:
Offline JC
Re: MFA & Acuracy?
« Reply #6 on: 04 May 2009, 20:55 »
well with changes of tyres for stretched etc etc etc  then yep, i doubt if ANY speedo therefore milage is accurate
i know mine over-reads 5mph across the board according to the sat nav  :grin:
Offline Ben Lessani
Re: MFA & Acuracy?
« Reply #7 on: 04 May 2009, 23:51 »
My MFA tells me I'm doing 7 MPG at about 20 MPH on the motorway :huh:
In reality its more like 45 MPG at about 100 70 MPH.
I've always gotten pretty good fuel economy though, but I put it down to how dense the cold air is, with it being -40 degs Celsius outside - or maybe my MFA is lying about that too
I don't even trust my MFA for the clock, as its never been right since I got the car - I cannot be bothered waiting till midnight just to pull the fuse and set the clock.
Offline gstar-dubworld
  • Here comes the piano man - his a peaceful man..
Re: MFA & Acuracy?
« Reply #8 on: 05 May 2009, 02:19 »
Better than guessing I suppose..
Mine averages 27~32 to the gallon and on a long run closer to 40, work our the total numbers of litres to a full tank, reset the trip counter and see how far your money takes, it's just sums at the end of the day don't need the MFA to tell you..
Offline Chris36
Re: MFA & Acuracy?
« Reply #9 on: 05 May 2009, 03:25 »
Thanks guys its answered my question - No. Its not reliable!! Best to work it out yourself. I will take a note of the miles once I fill it up.
