Author Topic: Fast(er) idle after winter fettling  (Read 861 times)
Offline nikkyboy
« on: 03 May 2009, 18:24 »
Hi,
Over the winter I've been doing a some work on my 8v Gti digi.  Its been dry stored in the garage.  When I started it after 5 months, after spluttering into life after a couple of attempts, (expected) I noticed it idled at 1250 rpm.  It used to be 850/900.
What could have caused this?  The stuff i've done to the engine was:
Clean out air intake hose.
Spray carb/injector cleaner into the inlet manifold.
Change the timing belt and tensioner (have I got it a tooth out?).
Replace the hot air hose that goes into the bottom of the airbox, the old one had holes in it.
Thanks
Nik
Offline H981CVV
Re: Fast(er) idle after winter fettling
« Reply #1 on: 03 May 2009, 21:10 »
if you've sprayed carb cleaner into the inlet manifold then it will idle high for a bit well it burns it off, however this normally will only last for a bit, it is also possible you altered the timing but its easy enough to check, sometimes it good to give the car a bit of a run just as its been laid up for a bit.
Offline nikkyboy
« Reply #2 on: 04 May 2009, 16:17 »
Cool, thanks for your help.  I've run the engine up to temp about 3 times, would the carb cleaner have burnt off by now?  I'll recheck the timing anyway but the run will have to wait until after I tax it.  Bloody bank holidays, nothings open when you want it to be  :grin:
