Author Topic: GTI sounding like a diesel...i just dont think its right!!  (Read 58641 times)
Offline cbp
Re: GTI sounding like a diesel...i just dont think its right!!
« Reply #120 on: 28 July 2009, 11:11 »
I have a 2L TDI and that developed a bad rattle, even for a diesel. It came from the inlet. With the bonnet up just behind the grill on the left side, there is a plastic box bolted to the front cross member with a 60mm diameter plastic pipe linking this to the airbox. The air pipe had worn enough to be no longer a tight fit. Hence it vibrated and rattled very loudly. I have only done 65000 kms. I cured it with a piece of self adhesive foam packing. Time to find noise: on and off for about two weeks. Time to effect the cure 20 minutes.
Incidentally if the noise is coming from the pipes under the floor try using silicon sealer as an alternative to plastic foam (mentioned in an earlier post). Clean any dirt and grease off both surfaces, poke the nozel between them and squirt out a button of silicone. Press the pipe into silicon and let it settle where it wants to. If necessary you can push the silicon in place with a licky-spit finger. When dry, (give it 24 hours) the gap is gone and the pipe is secure without any tension being applied. I have used this method on several cars where wiring looms or hoses touch each other or the body. It is surprising how quiet you can make an engine bay.
Offline Gene Hunt.
« Reply #121 on: 28 July 2009, 12:07 »
Hey Steve (Gene Hunt!!)
Got your mail, but get an error when tryin to reply......
Yes mate, after having all of the parts replaced the noise has gone.  Your symptoms sound exactly the same as mine were.  If your dealer gets stuck I am sure they could contact where I had mine fixed to get clarification - Wayside Dunstable 01582 500300 (ask for Hugh)  Sounds sooo much better, like it should.  Still running sweet as now and passed MOT on Friday - although got advisories on pads and discs, I have spent shed loads on this car, hmmmm!!!!!
Hope yours gets sorted mate, let me know how you get on.
Chris
Chris thanks for that mate.As in my pm it's going to my local vw dealer as soon as my sisters neighbour gets back off his hols(hes a tech down there).Thanks again for the help & the number i'm shure it will be a great help.
Steve.
Candy White ED35.
Offline cojomo2
« Reply #122 on: 17 May 2011, 12:06 »
Hey, sorry - just got back from being away!!
Right, invoice is as follows (not including cambelt and waterpump):
"Checked and reported on noise from cam-chain area. On further investigation found noise to be from cam-chain and variator.  Supplied and fitted cam-chain, variator and tensioner and all associated parts"
Cover £72.06
Premium charge £5.00
Bolt x 2 £1.81
Bolt x 1 £3.05
Bolt x 1 £3.15
Nut x 3 £0.47
Bolt x 1 £2.05
Bolt x 6 £0.60
Gasket £3.77
Adjuster £251.94
Chain £38.46
Tensioner £62.70
Valve £57.75
Labour £422.96
Labour includes time for cambelt and waterpump!!!!
Hope this helps!!!! If you need anymore info, just let me know.
Sorry for bumping an old thread, but desperately looking for advice. My mkv gti makes this diesel like noise at idle once it warms up. Showed mechanic this thread and he has agreed to replace all the above parts you mention, but I have no warranty..
Can anyone confirm if ALL those parts need replacing? I have read another thread where the guy indicated he only changed the chain and tensioner, and it did the trick? Don't want to replace the adjuster if there is no need..any advice welcome.
My car sound similar to this:
http://www.youtube.com/watch?v=b5jqHkD0qKM
