Author Topic: Need some spacer help  (Read 3146 times)
Offline Khare
  • The bear that khares
« on: 01 May 2009, 19:47 »
What is the MAX width spacer I can use with STANDARD VW bolts?
Offline Adam
Re: Need some spacer help
« Reply #1 on: 01 May 2009, 19:54 »
Get some hub-centric spacers. If you get some cheap nasty ones you will have some major high speed juddering.
If you value your life buy new bolts no matter what mm you gain!
Take out a bolt on your wheel and see how much actually holds the wheel on!
Down Hill From Here.
Offline Khare
« Reply #2 on: 01 May 2009, 19:56 »
Im just looking around atm, cos rallydesigns have some cheap pnes for like £20 including bolts aswell! not bad.
« Reply #3 on: 02 May 2009, 12:19 »
Much better to pay more for spacers to be honest.
Offline Khare
« Reply #4 on: 02 May 2009, 12:22 »
nice one mate. Just what i wanted to know. Will have to let spacers pass then.
Offline Shady Pioneer
  • graphic designer.
« Reply #5 on: 02 May 2009, 12:31 »
:grin: :grin: :grin:
I'll get spacers for the rear eventually, but that's at the bottom of my list of things to do as you know  :wink:
Offline Khare
« Reply #6 on: 02 May 2009, 12:54 »
rears are alright in my eyes, im looking at some spacers for the front.
Offline DANNYGCL
  • but plug thumb and jizz cookie)
« Reply #7 on: 02 May 2009, 13:05 »
I gotta get a 10mm going on the back of mine, it looks out of proportion, plus it will event he wieght out a bit and hopefully have a eeeeeeny weeeeny more grip or less roll  :cool:
usually I am listening to my own pistons trying to make a bid for freedom through the sump
Offline Khare
« Reply #9 on: 03 May 2009, 11:16 »
