Author Topic: BBM solid front engine mount  (Read 3290 times)
Offline LazyLunatic
  • MK3 20VT Project
« on: 01 May 2009, 00:56 »
looking at getting a solid front engine mount.
anyone got one?
i heard very good things about the bbm ones, get them from g-werks for £79.99
worth it?
cheers :)
Offline Martz
Re: BBM solid front engine mount
« Reply #1 on: 01 May 2009, 00:58 »
I have had one and it is great for getting all the powerdown to the wheels. Be prepared though to replace parts more often as the extra stress will shake everything like nuts! Well worth it though imo.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2 on: 01 May 2009, 10:22 »
ideal cheers m8. if it helps get power down, im all in. not too bad of a price. cheaper than a thought for an engine mount from BBM tbh.
VeeDubGTI16v
« Reply #3 on: 01 May 2009, 10:45 »
how bad it vibrates the car depends on what bushes the front subframe has. rubber bushes then you will barely notice it, poly bushes and you get a bit of vibration through the pedals etc. its not that bad really. it gets a lot worse when you uprate the gbox and rear mounts!
id start using loctite on all the bolts though! put lots on the solid mount bolts
Offline LazyLunatic
  • MK3 20VT Project
« Reply #4 on: 01 May 2009, 10:57 »
running a few polybushes on the front, wishbones and arb, not subframe mounts or rear/box mounts though. loctite ftw is it? sounds like a plan, dnt want bolts falling off lol.
cheers :)
VeeDubGTI16v
« Reply #5 on: 01 May 2009, 11:18 »
yep loctite is gooood. id suggest poly bushing the subframe as well, it sharpens the front up a treat
Offline LazyLunatic
  • MK3 20VT Project
« Reply #6 on: 03 May 2009, 17:56 »
cool, thanks for your help. will need to grab some loctite and i wil order the BBM mount after the bank holiday.
Offline ReDBull
« Reply #7 on: 05 May 2009, 14:21 »
I've been thinking about fitting a Vibratechnics front engine mount before I put my 4 branch manifold on. Wpuld you recomened a solid one instead?
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline LazyLunatic
  • MK3 20VT Project
« Reply #8 on: 05 May 2009, 18:05 »
im trying to find out really. BBM one is cheaper i think. looking at the above comments, i'd say the solid mount was better, but it needs the correct prep to ensure it works well - i.e. loctite.
i've got a bbm on the way, should be fitted as soon as it arrives, so will post up when i have tested it.
« Reply #9 on: 06 May 2009, 17:26 »
suspension makes a difference as well I think. my mates abf was more rattly at idle than mine, we both had 16v/g60 rear mount + bonded rubber gearbox & bbm solid front, and both had oem subframe bushes. only difference was I have a gsf lowering kit, he had coilovers. though maybe my subby bushes were worse than his  :grin:
