Author Topic: engage starter motor direct from battery???  (Read 5911 times)
Offline whit
« on: 30 April 2009, 19:43 »
i'm having some starting trouble and wondered if i can (using a couple of jump leads) directly connect the battery to the starter motor/solenoid to crank the engine??? :shocked:
Offline Len
Re: engage starter motor direct from battery???
« Reply #1 on: 30 April 2009, 19:46 »
Yes
www.sas.org.uk
www.the-ace.org.uk
Offline whit
« Reply #2 on: 30 April 2009, 21:45 »
Yes
is it as simple as battery (+ve) to starter (+ve), battery (-ve) to starter (-ve) (or earth?).
do i need to connect them up in a certain order?
will jump leads be ok to use?
thanks
Offline Ben Lessani
« Reply #3 on: 30 April 2009, 21:53 »
What exactly are you trying to do? Are you bench testing the starter - or doing it whilst its on the car?
You just need to clamp the earth to anywhere on the starter casing and clamp the +ve to the +ve terminal on the solenoid. But you'll need to make a short length of wire to run from the +ve terminal on the solenoid to the spade trigger.
Offline whit
« Reply #4 on: 30 April 2009, 21:58 »
while it's in the car, as a means to start the car rather than bump starting :embarassed:
Offline Ben Lessani
« Reply #5 on: 30 April 2009, 22:02 »
Whats wrong with the existing wiring in the car? Is the starter not turning over at all, or is it weak?
Offline whit
« Reply #6 on: 30 April 2009, 22:04 »
not turning over at all, battery ok
Offline Ben Lessani
« Reply #7 on: 30 April 2009, 22:09 »
How do you know the battery is ok, how has it been tested?
When you turn the key, do you hear a click or nothing at all? If there is no click, it sounds like the solenoid. There should be a spade connector with a thinnish +ve trigger - make sure it is tight. If it is and still no joy, then use a small piece of wire and short the +ve feed from the battery to the spade, then post back.
That will at least rule out the solenoid / ign switch.
Offline whit
« Reply #8 on: 30 April 2009, 23:14 »
dont think there is any noise usually although sometimes hear the fuel pump prime.
i'll give that a try.
« Reply #9 on: 01 May 2009, 00:05 »
Your saying that it will not turn over, worth checking that the immob. has not stuck in.
