Golf mk2
16v hall sender
Topic: 16v hall sender (Read 838 times)
midz16v
GTI forum regular
16v hall sender
30 April 2009, 18:56 »
mines cracked where it meets the dist but the wires etc are all fine.
will i get away with glueing together or can u get new hall senders?
mattkh
Re: 16v hall sender
30 April 2009, 22:20 »
Hi
Put up a picture.
VeeDubGTI16v
Guest
Re: 16v hall sender
30 April 2009, 22:34 »
im pretty sure you have to buy a new dizzy, but you can get away with fixing it back on if the wires are ok. id just zip tie it in place
H981CVV
Re: 16v hall sender
01 May 2009, 07:11 »
gsf do complete exchange dizzys for not that much, mine was crack like yours but it caused to much strain on the wires and the started chaffing.
midz16v
GTI forum regular
Re: 16v hall sender
01 May 2009, 08:53 »
all is well i had it stripped to fit a new seal,the bit that broke was as it slides into the dist when its back together it holds fine.
cheers for the replies
Golf mk2
16v hall sender
