Golf mk2
16v headgasket
Topic: 16v headgasket (Read 2032 times)
beechymonza
mad beech
16v headgasket
29 April 2009, 18:05 »
i think my head gasket has gone aarrgggghh, creamy liquid in header tank, how hard is it 2 fix, an what kinda price am i facin
No guts No glory,
AudiA8Quattro
Forum addict
Re: 16v headgasket
29 April 2009, 18:11 »
Check the oil cooler isn't broke first.
beechymonza
mad beech
Re: 16v headgasket
29 April 2009, 18:21 »
some one else said that 2 me, i changed that 2 years ago though, but he told me 2 bypass oil cooler with copper pipe in both water pipes 2 see if its any better
No guts No glory,
AudiA8Quattro
Forum addict
Re: 16v headgasket
29 April 2009, 18:23 »
Sounds like a good idea in the short term, should rule it out.
beechymonza
mad beech
Re: 16v headgasket
29 April 2009, 19:15 »
could it be the head gasket though, or is this uncommon 2 go
No guts No glory,
Ben Lessani
The poor mans MK2 Haynes author
Re: 16v headgasket
30 April 2009, 07:25 »
Its a headgasket, its not a headgasket, its a headgasket, its not a headgasket ...
Compression test it already - everything else on it own is completely inconclusive.
beechymonza
mad beech
Re: 16v headgasket
Reply #6 on:
30 April 2009, 08:09 »
an this comp0ression test will tell me the answer i am looking for, cause i didnt wanna mess about with other stuff, i just wanted 2 get head gasket done straight away,
No guts No glory,
danny_p
Forum addict
Re: 16v headgasket
Reply #7 on:
30 April 2009, 09:22 »
well on the bounus side the head gasket is a piece of piss to do on the 16v.
chould be ether water cooler or the headgasket so unless the compression test shoults head gasket. id wack a diffrent oil cooler on it and see if that makes any differance. if not few more hours and do the head gasket
all the VW's have gone bar 1.
Conker
Re: 16v headgasket
Reply #8 on:
30 April 2009, 12:38 »
Quote from: danny_p on 30 April 2009, 09:22
Show off.
Easy if you can get the exhaust to bits, or slide it through the subframe. It took me the best part of a day to do this bit alone.
beechymonza
mad beech
Re: 16v headgasket
Reply #9 on:
30 April 2009, 17:56 »
right, there is a oil cooler in scrappy, im gonna rob that 2morrow, cause this all started just after i fitted a new seal; in the oil cooler last month, as it was pissin out oil, now it is in my water system, so im hopin its the oil cooler
No guts No glory,
Golf mk2
16v headgasket
