Author Topic: problem now car is lowered  (Read 1844 times)
Offline IanMK3
« on: 28 April 2009, 20:43 »
managed to install coilovers on the gti no problem yesterday untill we realised once we let the car down the inside of the wheels are rubbing onto the springs, i tried 5mm spacers today but that didnt cure it, so next step is stretched tires,   but i need some advice on what size to go for,   the tires on the car now are 205x50x15,     would 195x45x15 be enough?
Re: problem now car is lowered
« Reply #1 on: 28 April 2009, 21:03 »
Are they factory wheels if so they should be nowhere near the springs, you could switch to 195/50/15's or put 3mm spacers in.
195/45/15's would look silly to be honest.
Offline IanMK3
« Reply #2 on: 28 April 2009, 21:05 »
yeh there standerd gti wheels, i wonder if maybe the camber is set to far back?
« Reply #3 on: 28 April 2009, 21:06 »
Is it only the front, if so then yes I would check the camber.
Offline shepgti
« Reply #4 on: 28 April 2009, 21:09 »
would guess you have tighted the lower strut bolts wrong so there is too much camber.
Offline IanMK3
« Reply #5 on: 28 April 2009, 21:12 »
ok will do, ill go for the 195/50/15's to so it can definatly sit lower without trouble of rubbing
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 28 April 2009, 21:14 »
has to be the camber...mine got 195's so it didn't foul the arches at -75mm and they had loads of clearance on the inside (even the 205's did)
Offline shepgti
« Reply #7 on: 28 April 2009, 21:14 »
the height should make no differnce to the wheels rubbing on the springs... only the arches
Offline IanMK3
« Reply #8 on: 28 April 2009, 21:21 »
hmm ok, well im going to get new tires anyway, how about 185/55/15 on the standard 6 1/2J wheels?
  • Back in a Mk3...
« Reply #9 on: 28 April 2009, 21:31 »
195/50 to keep the speedo true  :wink:
