Golf mk2
KR gearbox options??
Topic: KR gearbox options?? (Read 1206 times)
Tom21
28 April 2009, 18:25 »
sent my gearbox from my kr engine off to be stripped down and re-build, got the phone call today that its fooked and may aswell through it away.
Just wanted to know what my options are? can I use a mk3 abf gearbox and will that be better? cant remember if they are cable shift?
cheers Tom
H981CVV
Re: KR gearbox options??
28 April 2009, 19:22 »
im currently running a 2.0ltr 8v gti mk3 box. Its a bit better on fuel and still pulls really well. 70 m.p.h in second and wont get to the limiter in 5th no matter how long you wait but still does 140m.p.h.
Tom21
29 April 2009, 23:01 »
so will a 020 be better off the lights?
danny_p
Forum addict
30 April 2009, 01:07 »
if you want short nippy ratios mk1 1600 gti box iirc the code is FD
all the VW's have gone bar 1.
Tom21
03 May 2009, 18:24 »
is that 4 or 5 speed?
danny_p
Forum addict
03 May 2009, 19:24 »
iirc its a 5 speed not meany of them about now tho
dan7
85 T25 camper, 90 Mk2 16v, 90 Caddy
Reply #6 on:
03 May 2009, 21:07 »
Depends what you're after really. Fit an 8v 'box, and you'll lose the high end revs of the std 'box. If you're after fuel economy, I've heard of people fitting the fifth gear out of a driver 'box. Personally, stick with the standard 'box and fit an LSD.....
danny_p
Forum addict
Reply #7 on:
04 May 2009, 02:13 »
try the mk1 close ratio box you'll find more revs there, sub optimal or high speed motorway cruseing tho
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #8 on:
05 May 2009, 17:16 »
i have an fd in my cabby 16v, it is proper quick off the line but as said its buzzy in 5th! (4.1k at 80mph)
possible solution is to swap in a taller 5th from a longer geared box, though if you go too mad the jump from 4th to 5th might be a bit much.
Golf mk2
