Author Topic: Best way to clean roof lining?  (Read 2207 times)
Offline mk3valver
« on: 28 April 2009, 13:20 »
Im needing some advise on getting a slightly grubby headlining clean without taking it out of the car? It's a mk3 Gti with a light slightly soft to touch lining. I just dont want to jump on it with a scrubbing brush and shampoo cos I can see a it spreading a dirty foam around.
Any advise much appriciated. Matt
Offline Guy
Re: Best way to clean roof lining?
« Reply #1 on: 28 April 2009, 13:26 »
have a looksee here...
http://www.elitecarcare.co.uk/upholstery-and-carpets.php
i find the poorboys APC just excellent... cleans everything!
Offline Dan J
« Reply #2 on: 28 April 2009, 20:29 »
biobrisk diluted in a spray bottle set on fine mist, lightly spray rooflining small areas at a time suck out with a wet vac :wink: repeat as required, close windows turn engine on,heaters on full heat and full blast should be dry in 30 mins to an hour :grin:
nearly forgot!! add a cappfull of zoflora antibacterial to the spray solution, will stop any bacteria from breeding whilst its wet and will leave a nice smell when dry.
Offline dan_apps
  • too low for british roads!
« Reply #3 on: 29 April 2009, 07:46 »
i been using a new scratch and stain squirty from autoglym and its really quite good, has had a load of stains out of my old mon's cars headlining. you have to scrub like a motha though with the little sponge that comes with and leave dry.
