Author Topic: Knock Knock!  (Read 1115 times)
Offline lukesGTI
Knock Knock!
« on: 27 April 2009, 20:34 »
My fault code reader device has picked up a Knock Sensor fault what does this do? Could this cause the missfiring im experiencing and if so how much for a newy? Thanks Chaps!
Offline grimmer
  • www.check-light-on.co.uk
Re: Knock Knock!
« Reply #1 on: 27 April 2009, 20:49 »
it sense knock basically on the bottom end, and retards or advance timing in the ecu to accomdate the knock.
MK3 GOLF GTI 8V  now converted to 16v!!
Offline Paul86S2
Re: Knock Knock!
« Reply #2 on: 27 April 2009, 21:58 »
Sometimes you can undo them, clean the surface up and then bolt them back on and this cures the problem. They need to be done up to the correct torque setting.
Paul
