Author Topic: MK4 GTi 1.8T Petrol ( AGU ) - Bluefin or Revo ? *** Now Revo'd ***  (Read 13590 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
R-Tech,   If you do get enough numbers to come up to Scotland,  give me a shout ( hopefully have the cash then )...  You lads have a good rep so I'd prefer one of you lot to map it....
On another note...  Regarding high chance of clutch/flywheel fecking after remap ;
Been thinking this one over a bit,  now my car is the 150bhp AGU, after a remap I'm looking at 185>190bhp max....
Here's the question is the clutch/fywheel on my AGU not the same as an early 180bhp GTi ?
If so then it should handle a remap without problems,  not much difference between 180bhp and 185+.....
Or is it the torque that buggers it up ?
Thanks lads...
Yeah, torque is the turning force of the flywheel.
TBH, if driven sensibly, there's no reason why it shouldn't have virtually the same clutch life  (especially on stage 1 AGU).
I managed to get ~70k from my clutch - 40k of them remapped with a couple of track days thrown in. ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
p.s.  180 box is 6 speed which = different clutch. ;)
Offline GTiHigh
Thanks for clearing that up for me Ivor,  I've a better understanding now... appreciate your help.
Duh !  180 has 6speed box,  now why didn't I twig to that  :rolleyes: must've had a blond moment ....
Thanks again bud,
Just done my airbox smoothing and pipercross panel filter in prep for remap woohooo...
1999 - 1.8T ( AGU )
TB Clean
Forge 007P
Pipercross Panel Filter & Smoothed Airbox
Revo Remap - 190 bhp - 225 Torque
Offline mike 20v turbo
i just got my car remapped from star performance. its a big improvement and they had just reduced prices for 1.8t :smiley:
Offline GTiHigh
Hi Mike,  thanks for that...  how did you find the improvement ? ( edited: re-read your post -BIG improvement duh....nice one m8 )
I've been thinking more about this - was going to buy the BlueFin off ebay then get it reprogrammed by Superchips,  however I sent an email to Superchips for a price to reprogramme.  Unfortunately they don't supply BlueFin remap for MK4 Golf,  only MK5 and above.
Only got one option left really - Revo ( which I'm happy about, good name for themselves etc.. ) and their sort of close to me ( highland branch in Inverness )
Star performance sounds like their pretty sh!t hot !  hope your happy with the results  :evil:
Did you install a Forge 007p first ?  Ordered mine today off fleebay,  should get the remap next month
Cheers bud
« Last Edit: 18 May 2009, 23:06 by GTiHigh »
1999 - 1.8T ( AGU )
TB Clean
Forge 007P
Offline GTiHigh
Ok pretty pissed off now,  I emailed Revo for a price as their website now only displays in euros....  reply - £349 + vat....  christ a few weeks ago it was only £290ish inc vat...
Aww well,  not getting it done now ( for a while anyway )
Now I know everyone here recommends Rtech or Revo and I can understand why - but due to location ( and Revos price ) I'm kinda screwed but has anyone tried the KWP2000 of ebay - works with Golf 1.8t ME7.5 ( what's the ME7.5 mean ? )
Any thought ?
http://cgi.ebay.co.uk/KWP2000-Plus-KWP-2000-ECU-REMAP-Flasher-Tuning-Tool-UK_W0QQitemZ280307920904QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item280307920904&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
« Last Edit: 20 May 2009, 20:47 by GTiHigh »
1999 - 1.8T ( AGU )
TB Clean
Forge 007P
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Any thought ?
Hello,
The tool on ebay will work with the AUM/AUQ ecus, only if you can get the special me7.5 software add on, but once you can read and write the ecu you will find it hard to get a good remap file sent you which will please you AND your car.
Your AGU will be running the M3.3 ecu which NO obd tool can read, the only way to read your ecu is to take the chip out. There are a handful of tools, like MPPS and SPI wizard which can remap your ecu via the OBD port using the L-line+12v protocol.  Most companies will have to remove the chip to remap the ecu.  I know, AMD, Custom Code Revo & R-Tech can remap the ecu via obd due to them having invested in the correct tools.
Nick
 01455 617233
Offline GTiHigh
Thanks for the info Nick,  I apreciate it !
I'm also following J4LDOs thread re - remap via post  :cool:
I'll have a think and PM u if I want to take it any further..
Thanks again Nick your a star
1999 - 1.8T ( AGU )
TB Clean
Forge 007P
Offline RTechUK
If your woried about posting your ecu you could always PM RevoKev on this forum and explain your situation and see if you can twist his arm fo some discount in return for a review.. :wink:
If your thinking of a postal remap you will need to have your car checked out via vagcom before sending the ecu to us.  I am sure there will be someone local to you will have vagcom they can lend you.
Nick
 01455 617233
Offline J4LDO
GTI High
Buy the lead off ebay 12 quid with the software for Vag Com
Its simple to do, well check fault codes anyway
