Golf mk3
hardmonkeys
coilovers fitting question
Topic: coilovers fitting question (Read 1173 times)
IanMK3
26 April 2009, 21:38 »
does anybody know the diamiters for the 18mm bolts that you remove from the bottom of the strut assembly? as im installing my coilovers tomorrow and wont to replace these as i go along....
Wayne
Sir Postalot
Re: coilovers fitting question
26 April 2009, 23:37 »
If you mean the 2 bolts that hold the strut to the hub then get them from Vw, not expensive but needs to be a higher grade then you can buy.
Adam
Forum addict
26 April 2009, 23:43 »
M12x58
Down Hill From Here.
Wayne
Sir Postalot
26 April 2009, 23:47 »
Quote from: GTiAdam on 26 April 2009, 23:43
M12x58
Correct size but they are a higher strength bolt than standard over the counter items.
Adam
Forum addict
26 April 2009, 23:48 »
A2 grade?
Wayne
Sir Postalot
26 April 2009, 23:50 »
Quote from: GTiAdam on 26 April 2009, 23:48
A2 grade?
Not 100% sure but they and the nut have a built in washer as well, they were not expensive from Vw and it is not something you want to fail really.
IanMK3
Reply #6 on:
27 April 2009, 07:35 »
ok thanks, are they the same size bolts on the rear suspension to?
Golf mk3
hardmonkeys
