Author Topic: Golf dumping its water on the ground....  (Read 1616 times)
Offline Llewellyn
« on: 26 April 2009, 12:10 »
When the golf gets hot now, it dumps all its water on the ground.
It does its when it get to just above half on the temp gauge.
I have changed the cap for another second hand one, of my dads audi 80, which was operating fine on my 8v gti, but it still does it.  There is no sign of headgasket failure thats over pressurising the system, so i'm not sure what it could be.
I can pick up another cap tomorrow from GSF and see if that changes things, but the cap that was on it looked newish.
Not sure what next
cheers
James
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline H981CVV
Re: Golf dumping its water on the ground....
« Reply #1 on: 26 April 2009, 13:03 »
thermostat?
Offline Llewellyn
« Reply #2 on: 26 April 2009, 13:09 »
Just ran it again. the cap doesnt seem to pull down quite right onto the expansion tank.
When you tighten it as it seals, the thread pops off as it gets tight.
Also when you squeeze the top hose to the rad, i can hear air escaping through the cap. Surely this should be sealed?
James
« Last Edit: 26 April 2009, 13:38 by Llewellyn »
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline wil0
« Reply #3 on: 26 April 2009, 13:54 »
Where is the water coming from? the actual filler cap?
3Door Oak Green 91 MK2 16v GTi
Offline jamie_pyrite
« Reply #4 on: 26 April 2009, 14:21 »
Check the rubber o ring inside the cap. If it comes off its placement it causes pressure to escape. Just buy a brand new one for under a tenner from the Dealers to be safe. Make sure you get the blue cap.
Offline Llewellyn
« Reply #5 on: 26 April 2009, 14:34 »
The water is coming from the cap.  Im surprised both caps are duff, but surely i shouldnt here air when i squeeze the top hose.
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #6 on: 26 April 2009, 14:53 »
New header and cap may be the way to go. The plastic threads may be getting a little tired after nearly twenty years of screwing! I think I may be a little tired to after so much screwing too.  :lipsrsealed: :grin:
Offline Uruk Hai
« Reply #7 on: 26 April 2009, 15:17 »
I had this problem on mine so from experiance I would advise that you buy geniune parts, they cost more but they are better qaulity items.
Offline sidecarphil
« Reply #8 on: 26 April 2009, 17:42 »
+1
but i bought from a scrappy
again i'l cheap though LOL
Offline Martz
« Reply #9 on: 26 April 2009, 17:46 »
Agreed, I bought one from GSF and it was not great, so I got one from VW and it has been fine.
+1
