Author Topic: mk3 golf estate wishbone  (Read 3557 times)
Offline *tell*
« on: 26 April 2009, 09:29 »
i replaced the passager side wishbone a few months ago.
now the problem is when braking hard or driving over a pothole (that i try to miss)
the a loud knocking noise from that side?
i looked on euro car parts the list two wishbones hatchback and estate?
wot to do  :undecided:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: mk3 golf estate wishbone
« Reply #1 on: 26 April 2009, 12:54 »
Well, As far as i know there are only two,  GTI and Non GTI, yours would be non GTI i would imagen so thats correct,  First off, check out the anti roll bar links! i paied £7.00 for mine and that stoped the rattly knock over bumps,  i get a big crack/clonk over speed bumps which was the top mounts, neither are much money so give the wishbones a good yank and see if they are loose or have splits in the bushes, if there is no obvious damage stick ARB links on and then try top mounts.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
« Reply #2 on: 26 April 2009, 16:27 »
The wishbone would be the same, I would think your top mount has had it.
