Golf mk2
What is it ???
Topic: What is it ??? (Read 695 times)
erb91
What is it ???
25 April 2009, 22:28 »
When i was taking off the front end of the mk2 (GTi) the other day i noticed on the drivers side chasis leg below the aribox a small green tube just a bit bigger than an AA battery with two wire's coming out of each end... or there should be, the bottom wire had snaped off. What is it
Mr Blue
Forum addict
Re: What is it ???
25 April 2009, 22:40 »
Think you mean that coil thingy thats rivited to the chassis leg.
Dipped beam coil i think they call it?
Solder it back on or bin it if you have an uprated headlamp loom
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: What is it ???
27 April 2009, 08:34 »
yeah dim dip, follow the wires from it to a 2 pin plug and disconnect. not required for mot or by law, and the wires often rub thru on the chassis leg and cause the headlight loom to melt.
Golf mk2
What is it ???
