Author Topic: mk2 8v digi flooding petrol  (Read 3777 times)
Offline vdubmadness
« on: 24 April 2009, 22:00 »
hi all im needing help to sort out her indoors 8v gti on a h plate.
ive changed the plugs.leads.dizzy cap.rotorarm.new blue temp switch.
set timing and co the rite way,also changed the airflow metre/
car still floods with petrol on start up.takes a few turns then stinks of petrol
and floods engine so have to rev it up to clear then runs well till u turn it off.
will start first time sumtimes. any help please.
Offline wampablo
  • 2nd mk4
Re: mk2 8v digi flooding petrol
« Reply #1 on: 24 April 2009, 23:36 »
mine was flooding the other day and thought it was ecu not to sure if it was but swapped it and cleaned all the earths in the engine bay. also on the number 67 relay there was a bridge wire that previous owner had put on there that kept pump running constantly so took that out and slapped the relay a few times and seems to have sorted it out. so now im thining my flooding problem was down to that wire and relay so id look at that first. what is your fuel pump doing b4 you start it ? does itprime then go off or stay on ?
Offline vdubmadness
« Reply #2 on: 25 April 2009, 00:41 »
the pump buzz wen you turn the ignition on then stops. the goes soon as engine starts
Offline danny_p
« Reply #3 on: 25 April 2009, 19:54 »
vac line to fuel pressure reg is worth checking
all the VW's have gone bar 1.
Offline vdubmadness
« Reply #4 on: 26 April 2009, 20:39 »
i have renewd all vac pipes.
Offline danny_p
« Reply #5 on: 27 April 2009, 01:04 »
pull your fuel rail and injectors and see if they are stuck open or playing billy suggers
Offline Ktuludays
« Reply #6 on: 28 April 2009, 16:33 »
just con check the fuel rail in situ. haynes will give you readings to expect.
this will tell you if the injectors are biffed.
<br /><br />What don\'t kill ya, makes you more strong!
Offline vdubmadness
« Reply #7 on: 28 April 2009, 20:34 »
think il ave to get the fuel rail & injectors out on weekend to check seals,it stinks of petrol only on starting. smells strong on top of injectors engine floods and chokes up then few revs and then clears.
ive cleaned all  eath straps,wot about the coil......
Offline danny_p
« Reply #8 on: 28 April 2009, 21:14 »
that won't tell you much TBH   it will tell you if there are any electrical faults but the only electrical thing in an injector is a coil of wire.  if the injector has stuck it will still have the same reading just spray fuel all the time and this is a much more common type of injector fail.
Offline vdubmadness
« Reply #9 on: 29 April 2009, 22:50 »
ive seen posts on here about ecu's how will i know if its that.
or will i be better off buying a set of injectors
the co passed mot today so only over fueling on start up
