Author Topic: g60 running on 3 cylinders  (Read 1505 times)
VeeDubGTI16v
« on: 24 April 2009, 20:45 »
today my g60's no1 cylinder decided to stop working. i have been through the ignition system, leads, plugs, cap and rotor. this made no difference. when running you can disconnect the no1 ht lead and it makes no difference to the running. I think theres fuel going to it as with plugs in 2,3,4 and not in 1 i can smell fuel. Also did a compression check and all is fine.
am i missing something? im not that familiar with the g60 yet!
my thoughts are it must be fuel related as ive changed all the ignition bits. ive left the coil as i would have thought if thats broken it would affect all 4 cylinders
Offline danny_p
Re: g60 running on 3 cylinders
« Reply #1 on: 25 April 2009, 19:48 »
sounds like an injector has given yup   pull them out and swap two over,  DF1 is batch injection so fires all ionjectors together, if misfire moves its the injector if it remains on cyl 1    or dissapears alltogerther it the fuel rail rail loom
all the VW's have gone bar 1.
VeeDubGTI16v
« Reply #2 on: 25 April 2009, 20:36 »
i did all that today and yup its an injector at fault, good call!
hopefully it can be cleaned/serviced as i dont want to fork out £50 for one :shocked: ive tested the resistance on the injectors and they are all showing the right value so hopefully ones just clogged up
« Reply #3 on: 27 April 2009, 08:14 »
do the lot as a set though, last thing you want is a set of missmatched injectors.
VeeDubGTI16v
« Reply #4 on: 27 April 2009, 11:42 »
im getting them all getting cleaned at the moment so fingers crossed that sorts it!
