Author Topic: Is a passat gli gearbox same as golf gti  (Read 2031 times)
Offline r7quad
« on: 31 July 2004, 09:18 »
Hi
Does anyone know if the gearbox in a passat gli 1990 will fit,and is geared the same as a box in a 1990 golf gti 1800 8 valve ?
Ben
benleberl@hotmail.com
Offline richandhazel
Re:Is a passat gli gearbox same as golf gti
« Reply #1 on: 31 July 2004, 13:38 »
Doesn't the engine fit 'inline' on the Passat and therefore the gearbox will sit in the tunnel?
Golf engine is fitted transverse and so the gearbox is fitted on the end.
That being the case, they will be completely different.
golfvr6
« Reply #2 on: 31 July 2004, 14:06 »
No, the Passat 1990 is a tranverse engine.
But i think the Passats use cable change gearboxs with hydraulic clutch, so no it won't fit the Golf.
« Reply #3 on: 31 July 2004, 15:37 »
Must be the older Passat's that were 'inline', cheers '6.
golfvr6
« Reply #4 on: 31 July 2004, 16:19 »
yep the model before was an inline engine  ;)
