Author Topic: remap anni with hybrid turbo,  (Read 1852 times)
Offline brianpologti
« on: 23 April 2009, 20:34 »
hi I was wondering if you could do a remap for my golf, its a aqu, with agu bottom end, with hybrid turbo, front mounted intercooler,sports cat  (think n75 j valve) silcone pipes etc,
At the moment its running completely standard map, also I cant seem to get the dump valve to work with this set up, but it works ok on a different car,
Offline Ben
Re: remap anni with hybrid turbo,
« Reply #1 on: 24 April 2009, 10:38 »
Hello,
What turbo have you used?  Have you change the fuel delivery system? We should be able to get your car up and running right and remapped. Where are you from?
ben
the dwarf from the north
« Reply #2 on: 24 April 2009, 19:12 »
It's a ko4 in ko3s case the fuel system is standard. Should I uprate the fuel pump,or injectors or fuel regulator? I am at j6 m1 so about a hour and a half is away,
« Reply #3 on: 06 May 2009, 09:19 »
shall I give you guys a ring sometime to book it in for a remap?
Offline wayne_gtiT
« Reply #4 on: 06 May 2009, 18:25 »
check ur msg's
« Reply #5 on: 07 May 2009, 16:56 »
pm'ed you back :smiley:
