Author Topic: none starter!!!!  (Read 1993 times)
Offline Ben Lessani
Re: none starter!!!!
« Reply #10 on: 24 April 2009, 17:41 »
If its Digi, then ignore everything I said :laugh:
I don't know much anything about Digi, but I'm sure others can help!
« Reply #11 on: 24 April 2009, 17:46 »
have you disconnected the fuel lines off the rail at any point?
Offline jayb_09
« Reply #12 on: 25 April 2009, 12:03 »
no haven't disconnected any of them?? could it be something to do with a blockage in the fuel lines??
« Reply #13 on: 27 April 2009, 08:29 »
wasgoingto say they could be back to front, but thats ruled out. maybe the fpr on the end of the rail has packed in, or the injectors are not firing.  if you crack loose the pipe to the plastic fuel rail, is there fuel in there?  Check the wires to the end of the fuel rail havent snapped.  If it looks good, check the red wire on the rail, this should be live whenever the fuel pump is on.
Offline jayb_09
« Reply #14 on: 01 May 2009, 13:49 »
right then i have taken all your advice and im gonna give it a good go at trying to start the golf over the weekend...im gonna try the injectors because i think it is those so how do 1. get to the injectors 2. get the injectors off so i can see if there blocked?? 3. if they are blocked how do i go about by unblocking them if it is that?? cheers
