Author Topic: Fuses for MFA Reset  (Read 3459 times)
Offline Goops
  • mk2 gti 16v
Fuses for MFA Reset
« on: 23 April 2009, 01:39 »
Hello people,
Was driving 2 nights ago and the car randomly cut out coz it was not idling correctly. :huh:
Anyway, this happend twice and since my MFA has been stuck on the clock mode!
The stalk button presses do not get registered and I can not access the other options.
 :angry:
I disconnected the battery last night and it still comes up only with the clock?
I understand disconnecting fuses for the clocks can also reset the mfa readout memory?
http://www.golfgtiforum.co.uk/index.php?topic=44637.0
Could someone kindly outline which fuses I need to pull out?
At the moment, I gather:
U1 - 14
U2 - 14
Thanks in advance,
Goops
Offline wampablo
  • 2nd mk4
Re: Fuses for MFA Reset
« Reply #1 on: 23 April 2009, 08:52 »
i wouldnt have thought pulling fuses would make much difference if you have already dissconnected the battery more or the less the same thing id have thought
Offline jezza16v
« Reply #2 on: 23 April 2009, 09:03 »
This happened to me, I spent ages messing with battery & fuses and it turned out that the MFA connector plug in the column cowling had been accidentally pulled apart (by a careless immobiliser fitter).  :rolleyes:
« Reply #3 on: 23 April 2009, 09:58 »
fuse 21 is the one that will reset the clocks :)
U1/2 14 are plug/pin numbers on the rear of the fusebox.
Offline Goops
  • mk2 gti 16v
« Reply #4 on: 23 April 2009, 10:56 »
aha, brilliant! Thanks eevryone, I will pop out the fuse and disconnect the battery at lunch!
Hope this works!
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #5 on: 23 April 2009, 15:59 »
Could be an earth ... Maybe :huh:
Offline Goops
  • mk2 gti 16v
« Reply #6 on: 24 April 2009, 01:24 »
hmm disconnected the fuse and battery at lunch, still only shows the clock and not the other functions? :sad:
Il get a free halfords battery check over the weekend (read on here that un underpowered battery can show such symptoms)?
Will look at this however i didnt touch any of this to create the problem!
Any ideas on where to start looking?
Thank you!
Offline bomp
« Reply #7 on: 24 April 2009, 08:37 »
Just turn the key so the ignition lights come on, or have the car running, then pull fuse 21 out, (no need to disconnect the battery), then put it back in again.  Some people say wait for 30 seconds before putting it back in again, to reset.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline AdamMk2
  • Beautiful
« Reply #8 on: 27 April 2009, 22:00 »
This is very interesting, am going to investigate this  :wink:
Thanks
Ad
