Poll
can anyone help please
knock sensor
1 (50%)
distributor
1 (50%)
Total Members Voted: 2
Author Topic: gti mk 2 running retarded  (Read 1128 times)
Offline ghandi
« on: 22 April 2009, 19:25 »
hi im gary ,i have a mk 2 gti and its running retarded,(its as if the automatic choke is on but there aint any )  ive put a new distributor and a new knock sensor (from germany ) in & had my timing checked , can any1 please help
Offline Diamond Hell
  • Opinions я Us
Re: gti mk 2 running retarded
« Reply #1 on: 22 April 2009, 20:49 »
Did you torque the knock sensor down to the specified setting?
No Andywash option on the poll?
Offline jezza16v
« Reply #2 on: 22 April 2009, 21:30 »
8v or 16v, if 8v is it a kjet or digi? What makes you think its 'retarded'? The kjets do have a sort of automatic choke ie the warm up regulator and I guess the digis have something similar. You may have a faulty water temperature sender which is telling the engine it is 'cold' all the time. It could be that the mixture is running really rich, really weak or you have a vacuum leak somewhere.......perhaps the cambelt has slipped a couple of teeth? So many things it could be really. Any more info on the symptoms?
Offline Martz
« Reply #3 on: 22 April 2009, 21:34 »
Andywash ftw!
Not really sure how you can go on this, what exactly is it doing?
Offline Conker
« Reply #4 on: 22 April 2009, 22:45 »
No knock sensor on K-Jet.
Offline jezza16v
« Reply #5 on: 22 April 2009, 22:58 »
^^ Well spotted  :rolleyes:
Offline ghandi
« Reply #6 on: 24 April 2009, 14:40 »
its 8 v and digi mate
Offline squires
« Reply #7 on: 24 April 2009, 17:31 »
mine had been running poorly at low revs exhaust popping etc, struggled to climb hills, changed my knock sensor as my old one was split, plus the insulation was damaged, now runs a lot better and revs cleaner and more willing to climb hills. mines also a 8v digi
