Author Topic: big rotten hole  (Read 2436 times)
Offline juleshs
big rotten hole
« on: 22 April 2009, 19:24 »
took the battery out today and the battery mat and found this problem
is there a panel i can buy for this mess or do i have to try find a good welder in these monies too tight to mention days
can this be welded with it being stuctural???
Re: big rotten hole
« Reply #1 on: 22 April 2009, 20:16 »
I am not sure if you can get a panel but a good bodyshop should be able to cut it out and make a repair section as required.
Offline ...joe
Re: big rotten hole
« Reply #2 on: 22 April 2009, 20:48 »
you can buy the battery trays to wedl in but thats the chassis leg thats gone, so bodyshop or a good welder could sort it.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline molovin
Re: big rotten hole
« Reply #3 on: 29 April 2009, 12:27 »
little off topic but ive got some rust on the exterior of the car. It hasnt made a hole like above just surface rust. Would i need to cut this out and weld a piece in or could i just filler over it and ready for spray. Im new to golfs and never had rust on my cars before so really a dam right novice
Offline molegti
Re: big rotten hole
« Reply #4 on: 02 May 2009, 08:39 »
Sand it back to bare metal, fill then repaint. Haven't had a go my self yet but there is some useful info in http://www.mig-welding.co.uk/in the paint section. (Its also a pretty good site if you want to have a go at welding).
Offline the dude
Re: big rotten hole
« Reply #5 on: 02 May 2009, 14:51 »
sorry if this is thread hijacking, but I took off my rear nearside wheel, and noticed a big hole in my exhaust pipe, just before the big backbox? (I think thats what it is,) but obviously tat means my exhaust is blowing, is it a big job to repair/replace this part?
Got a service in a week too, oh the £!!!
Offline boo
Re: big rotten hole
« Reply #6 on: 02 May 2009, 16:52 »
im sure you can buy the bit of panel from vw
i think its called a chassis leg closeing plate
its been a while since i fitted one mind so it mite be
a discontinued part if that helps
Offline juleshs
Re: big rotten hole
« Reply #7 on: 05 May 2009, 23:34 »
yes there is such a panel rang vw today, there are only 4 of these left in existance, so one now as my name on it, when that arrives it will be off to a fabricators then there will be a lot more in existance at a lot less than vw knock hem out at
